下载附件
2015-7-28 10:17 上传
2015-7-28 10:14 上传
int pin = 8; unsigned long duration; unsigned long starttime; unsigned long sampletime_ms = 30000;//sampe 30s ; unsigned long lowpulseoccupancy = 0; float ratio = 0; float concentration = 0; void setup() { Serial.begin(9600); pinMode(8,INPUT); starttime = millis();//get the current time; } void loop() { duration = pulseIn(pin, LOW); lowpulseoccupancy = lowpulseoccupancy+duration; if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s { ratio = lowpulseoccupancy/(sampletime_ms*10.0); // Integer percentage 0=>100 concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve Serial.print(lowpulseoccupancy); Serial.print("concentration = "); Serial.print(concentration); Serial.println(" pcs/0.01cf"); Serial.println("\n"); lowpulseoccupancy = 0; starttime = millis(); } }
查看全部评分
签到天数: 4 天
GMT+8, 2024-12-31 02:01 , Processed in 0.071677 second(s), 28 queries .
