轨迹球模块
2017年3月16日 (四) 16:21Admin讨论 | 贡献的版本
轨迹球模块
轨迹球模块采用黑莓轨迹球设计制作,模块可以通过滚轮运动传动X和Y方向的转轴,通过固定在转轴上的多极充磁磁体转动,对相应的SMD霍尔元件发出信号,从而确定运动轨迹。轨迹球下方还设计了一个小SMD开关,方便用户进行触发事件或“点击”选择。
  • 模块尺寸:28*21*15.7MM(长*宽*高)
  • 模块重量:2.5g
名称 说明
RHT Sign - right
LET Sign - left
DWN Sign - down
UP Sign - up
KEY Sign - key
VCC 电源+5V
GND
轨迹球模块 Arduino UNO
RHT D4
LET D3
DWN D6
UP D5
KEY D2
VCC 电源+5V
GND
BlackBerry Trackballer Breakout Demo
//Define Trackballer Breakout pin connections to Arduino
#define Btn 2
#define Lft 3
#define Rht 4
#define Up 5
#define Dwn 6
//Define variables used in sketch
int buttonClick;
unsigned long mouse_Lft;
unsigned long old_mouse_Lft;
unsigned long mouse_Rht;
unsigned long old_mouse_Rht;
unsigned long mouse_Up;
unsigned long old_mouse_Up;
unsigned long mouse_Dwn;
unsigned long old_mouse_Dwn;
int x_position;
int y_position;
/*********************Setup Loop*************************/
  //Define pin functionality on the Arduino
  pinMode(Btn, INPUT);
  pinMode(Lft, INPUT);
  pinMode(Rht, INPUT);
  pinMode(Up, INPUT);
  pinMode(Dwn, INPUT);
  //Start Serial port for debugging.
  Serial.println("Begin Trackballer Demo");
  delay(1000);
  Serial.println("Begin Trackball tracking");
/*********************Main Loop*************************/
  //read the pin state
  mouse_Lft = digitalRead(Lft);
  mouse_Rht = digitalRead(Rht);
  if (mouse_Lft != old_mouse_Lft)
    x_position = --x_position;
    old_mouse_Lft = mouse_Lft;
    Serial.print("Trackball Position: \t X-Position= ");
    Serial.println(x_position);
  if (mouse_Rht != old_mouse_Rht)
    x_position = ++x_position;
    old_mouse_Rht = mouse_Rht;
  delay(50);
  mouse_Up = digitalRead(Up);
  mouse_Dwn = digitalRead(Dwn);
  if (mouse_Up != old_mouse_Up)
    y_position = ++y_position;
    old_mouse_Up = mouse_Up;
    Serial.print("Trackball Position: \t  \t Y-position= ");
    Serial.println(y_position);
  if (mouse_Dwn != old_mouse_Dwn)
    y_position = --y_position;
    old_mouse_Dwn = mouse_Dwn;
  delay(50);
  //Check for button click. If present, print to Serial monitor.
  buttonClick = digitalRead(Btn);
  if (buttonClick == LOW)
    Serial.println("Click");
程序下载地址:BlackBerry_Trackballer_Breakout_Demo
程序运行结果:转动轨迹球,串口输出X、Y轴位置信息,点击按键串口输出“Click”。串口监视器截图:
轨迹球串口输出
教程地址附视频
欢迎交流加入群聊-技术交流群
