一位来自葡萄牙的arduino爱好者,在他的BLOG中分享了一个基于Arduino平台的游戏,下面是他的作品:
原文地址:http://blog.bsoares.com.br/ardui ... d-matrix-on-arduino
利用常见的8*8点阵作为“游戏机”的显示屏,两个10K的电位器作为双方的“球拍”,控制器采用的是Arduino的Duemilanove兼容板。当顺时针拧电位器时,球拍向左移动;反向则向右移动。
游戏代码:- /**
- * Ping Pong with 8x8 Led Dot Matrix on Arduino
- * @author Bruno Soares
- * @website www.bsoares.com.br
- #include "TimerOne.h"
- #define PIN_LEFT 4
- #define PIN_RIGHT 5
- unsigned int left = 0;
- unsigned int right = 0;
- int angle = 0;
- int radians;
- byte rows[8] = {9, 14, 8, 12, 1, 7, 2, 5};
- byte cols[8] = {13, 3, 4, 10, 6, 11, 15, 16};
- byte pins[16] = {5, 4, 3, 2, 14, 15, 16, 17, 13, 12, 11, 10, 9, 8, 7, 6};
- byte screen[8] = {0, 0, 0, 0, 0, 0, 0, 0};
- volatile byte screenRow = 0;
- volatile byte screenCol = 0;
- int _angle;
- int _px;
- int _py;
- int _w = 7;
- int _h = 7;
- int _wall[] = {3, 3};
- int _count = 0;
- int _speed = 3;
- int _countPoints = 0;
- void setup() {
- Timer1.initialize(100);
- for (int i = 2; i <= 17; i++)
- pinMode(i, OUTPUT);
- Timer1.attachInterrupt(doubleBuffer);
- Serial.begin(9600);
- face();
- reset();
- void doubleBuffer() {
- digitalWrite(translatePin(rows[screenRow]), LOW);
- digitalWrite(translatePin(cols[screenCol]), HIGH);
- screenCol++;
- if (screenCol >= 8) {
- screenCol = 0;
- screenRow++;
- if (screenRow >= 8) {
- screenRow = 0;
- if((screen[screenRow] >> screenCol) & B1 == B1) {
- digitalWrite(translatePin(rows[screenRow]), HIGH);
- digitalWrite(translatePin(cols[screenCol]), LOW);
- } else {
- byte translatePin(byte original) {
- return pins[original - 1];
- void allOFF() {
- for (int i = 0; i < 8; i++)
- screen[i] = 0;
- void on(byte row, byte column) {
- screen[column-1] |= (B1 << (row - 1));
- void off(byte row, byte column) {
- screen[column-1] &= ~(B1 << (row - 1));
- void calcWall()
- left = analogRead(PIN_LEFT);
- right = analogRead(PIN_RIGHT);
- left = constrain(map(left, 223, 800, 0, 6), 0, 6);
- right = constrain(map(right, 223, 800, 6, 0), 0, 6);
- clearWall();
- on(1, left + 1);
- on(1, left + 2);
- on(8, right + 1);
- on(8, right + 2);
- _wall[0] = left;
- _wall[1] = right;
- show();
- void clearWall()
- screen[i] &= B01111110;
- void clearGame()
- screen[i] &= B10000001;
- void loop() {
- calcWall();
- enterFrameHandler();
- delay(50);
- void enterFrameHandler()
- if (_count++ < _speed)
- return;
- _count = 0;
- checkCollision();
- calcAngleIncrement();
- show();
- void retorted(int angle)
- Serial.println(angle);
- _angle = angle;
- if (++_countPoints % 5 == 0 && _speed > 1)
- _speed--;
- void resetAnim()
- screen[i] = B11111111;
- delay(25);
- screen[i] = B00000000;
- delay(25);
- void face()
- on(1, 1);
- on(1, 2);
- on(2, 1);
- on(2, 2);
- on(7, 1);
- on(7, 2);
- on(8, 1);
- on(8, 2);
- on(1, 1);
- on(1, 2);
- on(4, 4);
- on(4, 5);
- on(5, 4);
- on(5, 5);
- on(2, 7);
- on(7, 7);
- on(3, 8);
- on(4, 8);
- on(5, 8);
- on(6, 8);
- delay(5000);
- void reset()
- resetAnim();
- _px = random(3, 5);
- _py = random(3, 5);
- _angle = random(0, 2) == 0 ? 0 : 180;
- _speed = 5;
- _countPoints = 0;
- show();
- delay(500);
- void show()
- clearGame();
- on(_px + 1, _py + 1);
- void checkCollision()
- if (_px == _w - 1)
- if (_angle == 315 || _angle == 0 || _angle == 45)
- if (_py == _wall[1] || _py == _wall[1] + 1)
- if (_angle == 0 && _py == _wall[1])
- retorted(225);
- else if (_angle == 0 && _py == _wall[1] + 1)
- retorted(135);
- else if (_angle == 45 && _py == _wall[1])
- retorted(135);
- else if (_angle == 45 && _py == _wall[1] + 1)
- retorted(180);
- else if (_angle == 315 && _py == _wall[1])
- retorted(180);
- else if (_angle == 315 && _py == _wall[1] + 1)
- retorted(225);
- else if (_px == 1)
- if (_angle == 225 || _angle == 180 || _angle == 135)
- if (_py == _wall[0] || _py == _wall[0] + 1)
- if (_angle == 180 && _py == _wall[0])
- retorted(315);
- else if (_angle == 180 && _py == _wall[0] + 1)
- retorted(45);
- else if (_angle == 135 && _py == _wall[0])
- retorted(45);
- else if (_angle == 135 && _py == _wall[0] + 1)
- retorted(0);
- else if (_angle == 225 && _py == _wall[0])
- retorted(0);
- else if (_angle == 225 && _py == _wall[0] + 1)
- retorted(315);
- if (_px == _w)
- reset();
- else if (_px == 0)
- reset();
- else if (_py == _h)
- if (_angle == 45)
- _angle = 315;
- else if (_angle == 135)
- _angle = 225;
- else if (_py == 0)
- if (_angle == 225)
- _angle = 135;
- else if (_angle == 315)
- _angle = 45;
- void calcAngleIncrement()
- if (_angle == 0 || _angle == 360)
- _px += 1;
- else if (_angle == 45)
- _px += 1;
- _py += 1;
- _px -= 1;
- _py += 1;
- else if (_angle == 180)
- _px -= 1;
- else if (_angle == 225)
- _px -= 1;
- _py -= 1;
- _px += 1;
- _py -= 1;
复制代码 对应引脚接线:(下图左侧红框内表示arduino接口,14为A0,15为A1 ...依次类推,“球拍”接A4及A5)
因为点阵显示单元就占用了arduino 主板16个IO引脚,如果想扩展比分显示单元,或者将电位器换成按键,几乎无法实现。我们可以利用74HC595来对点阵的引脚进行简化,通过下面的电路,我们在实际控制的时候只需要用到3根信号线即可搞定。
*因为是动态扫描显示,图中的8个限流电阻可以舍去,还可以提高亮度。
实物接线,用按键代替了电位器(更符合人们的操作习惯),另外加入一个液晶,可以实时的将游戏比分记录下来。
代码下载:
