查看: 39705|回复: 29
Arduino入门教程—拓展实验篇九 驱动单色8*8点阵
发表于 2013-8-18 15:21:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
驱动单色8*8点阵
本次实验使用Arduino 控制器直接驱动一个单色的8*8点阵,所用点阵型号为LD-1088BS,如下图:
收藏收藏 支持支持1 反对反对
推荐
发表于 2015-7-22 02:23:08 | 只看该作者
我补一个驱动5针LED的例子
D:\Documents\Bluetooth Folder\IMG_20150722_021849.jpg
[C++] 纯文本查看 复制代码
#include <FrequencyTimer2.h>
#define NOP() do { __asm__ __volatile__ ("nop"); } while (0)
#define _countof(a)		(sizeof(a) / sizeof(a[0]))
class HC595LED
public:
	HC595LED(int ser, int rck, int srck)
		_SER = ser;
		_RCK = rck;
		_SRCK = srck;
	void begin()
		pinMode(_SER, OUTPUT);
		pinMode(_RCK, OUTPUT);
		pinMode(_SRCK, OUTPUT);
		digitalWrite(_SER, LOW);
		digitalWrite(_RCK, LOW);
		digitalWrite(_SRCK, LOW);
	void displayRow(uint8_t nRow, uint8_t data)
		nRow = 7 - nRow;
		for(int i = 0; i < 8; i++)
			_rowEnable(i == nRow);
		for(int i = 7; i >= 0; i--) {
			_colEnable(bitRead(data, i));
		flushScreen();
	void clear()
			_rowEnable(false);
			_colEnable(false);
	void writeItem(bool bHigh)
		digitalWrite(_SER, bHigh ? HIGH : LOW);
		_flushItem();
	void flushScreen()
		digitalWrite(_RCK, HIGH);
		NOP();
		NOP();
private:
	void _rowEnable(bool bEnable)
		writeItem(!bEnable);
	void _colEnable(bool bEnable)
		writeItem(bEnable);
	void _flushItem()
		digitalWrite(_SRCK, HIGH);
		NOP();
		NOP();
private:
	int _SER;
	int _RCK;
	int _SRCK;
//Pin connected to DS of 74HC595
const int SER_PIN = 8;
//Pin connected to ST_CP of 74HC595
const int RCK_PIN = 9;
//Pin connected to SH_CP of 74HC595
const int SRCK_PIN = 10;
HC595LED led(SER_PIN, RCK_PIN, SRCK_PIN);
PROGMEM const char SPACE[] =
	0b00000000,
	0b00000000,
	0b00000000,
	0b00000000,
	0b00000000,
	0b00000000,
	0b00000000,
	0b00000000,
PROGMEM const char H[] =
	0b01000010,
	0b01000010,
	0b01000010,
	0b01111110,
	0b01000010,
	0b01000010,
	0b01000010,
	0b01000010,
PROGMEM const char E[] =
	0b01111110,
	0b01000000,
	0b01000000,
	0b01111110,
	0b01000000,
	0b01000000,
	0b01000000,
	0b01111110,
PROGMEM const char L[] =
	0b01000000,
	0b01000000,
	0b01000000,
	0b01000000,
	0b01000000,
	0b01000000,
	0b01000000,
	0b01111110,
PROGMEM const char O[] =
	0b00011000,
	0b00100100,
	0b01000010,
	0b01000010,
	0b01000010,
	0b01000010,
	0b00100100,
	0b00011000,
const char * const arrShowData[] = {H, E, L, L, O, SPACE};
char arrShowBuffer[] =
	0, 0, 0, 0, 0, 0, 0, 0,
void display()
	static int s_nIndex = 0;
	led.displayRow(s_nIndex, arrShowBuffer[s_nIndex]);
	s_nIndex++;
	s_nIndex %= 8;
	led.begin();
    delay(1000);
	led.clear();
	FrequencyTimer2::disable();
	FrequencyTimer2::setPeriod(2000);
	FrequencyTimer2::setOnOverflow(display);
	int s_nIndex = 0;
	while(true) {
		noInterrupts();
		memcpy_PF(arrShowBuffer, (uint_farptr_t)arrShowData[s_nIndex], sizeof(arrShowBuffer));
		interrupts();
		s_nIndex++;
		s_nIndex %= _countof(arrShowData);
		delay(2000);
回复 支持 2 反对 0
推荐
发表于 2015-7-22 21:30:03 | 只看该作者
推荐
发表于 2014-11-2 00:08:42 | 只看该作者
8*8点阵 反面5根针的 不明白 怎么弄。。。求救。。
发表于 2013-8-19 23:34:47 | 只看该作者
代码有误呀==
 楼主| 发表于 2013-8-20 08:40:14 | 只看该作者
发表于 2013-10-13 20:56:07 | 只看该作者
5555,我的YFrobot套件中的单色点阵型号是LD-1088BHG,上下各12个针脚,怎么安啊-_-#
你的应该是双色点阵,UNO的I/O口都不够咯。。需要连接芯片了  发表于 2013-10-15 19:19
 楼主| 发表于 2013-10-16 10:04:19 | 只看该作者
http://blog.bsoares.com.br/arduino/ping-pong-with-8x8-led-matrix-on-arduino
发表于 2014-1-7 21:11:41 | 只看该作者
不错不错,学习一下
签到天数: 6 天
发表于 2014-9-18 22:28:09 | 只看该作者
求问我这个反面5根针的怎么插? 有例程吗?
 楼主| 发表于 2014-9-19 18:02:31 | 只看该作者
根据你的程序来接线:
  1. //Pin connected to DS of 74HC595
  2. int SER = 9;
  3. //Pin connected to ST_CP of 74HC595
  4. int RCK  = 10;
  5. //Pin connected to SH_CP of 74HC595
  6. int SRCK  = 11;
发表于 2015-4-13 22:35:06 | 只看该作者
AllBlue 发表于 2014-9-19 18:02
根据你的程序来接线:
怎么弄啊,能不能详细点
GMT+8, 2024-12-22 00:19 , Processed in 0.073685 second(s), 35 queries .
