WiFi.config()
config()
WiFi.config(ip); WiFi.config(ip, dns); WiFi.config(ip, dns, gateway); WiFi.config(ip, dns, gateway, subnet);
ip: the IP address of the device (array of 4 bytes) dns: the address for a DNS server. gateway: the IP address of the network gateway (array of 4 bytes). optional: defaults to the device IP address with the last octet set to 1 subnet: the subnet mask of the network (array of 4 bytes). optional: defaults to 255.255.255.0
Nothing
This example shows how to set the static IP address, 192.168.0.177, of the LAN network to the WiFi shield: #include <SPI.h> #include <WiFi.h> // the IP address for the shield: IPAddress ip(192, 168, 0, 177); char ssid[] = "yourNetwork"; // your network SSID (name) char pass[] = "secretPassword"; // your network password (use for WPA, or use as key for WEP) int status = WL_IDLE_STATUS; void setup() { // Initialize serial and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } // check for the presence of the shield: if (WiFi.status() == WL_NO_SHIELD) { Serial.println("WiFi shield not present"); while(true); // don't continue } WiFi.config(ip); // attempt to connect to Wifi network: while ( status != WL_CONNECTED) { Serial.print("Attempting to connect to SSID: "); Serial.println(ssid); // Connect to WPA/WPA2 network. Change this line if using open or WEP network: status = WiFi.begin(ssid, pass); // wait 10 seconds for connection: delay(10000); } // print your WiFi shield's IP address: Serial.print("IP Address: "); Serial.println(WiFi.localIP()); } void loop () {} |
