8*8点阵模块
- 供电电压:DC5V
- 使用芯片:74HC595
- 模块尺寸:32.5*32.5*14.7MM(长*宽*高)
- 模块重量:10.6g
- 1. VCC -- Vcc(电源+5V)
- 2. GND -- Gnd(地)
- 3. SER -- 串行移位输入
- 4. RCK -- 存储寄存器的时序输入
- 5. SRCK -- 移位寄存器的时序输入
| 点阵模块 | Arduino UNO |
| VCC | +5V |
| GND | GND |
| SER | D10 |
| RCK | D11 |
| SRCK | D12 |
示例一:基本显示
Face.ino:
* Face
* ( 8x8 Led Dot Matrix with two 74HC595 on Arduino)
* by YFROBOT
#include "TimerOne.h"
#include "face.h"
#define ROW_DATA ((row[0]<<7)|(row[1]<<6)|(row[2]<<5)|(row[3]<<4)|(row[4]<<3)|(row[5]<<2)|(row[6]<<1)|(row[7]<<0))
#define COL_DATA ((col[0]<<7)|(col[1]<<6)|(col[2]<<5)|(col[3]<<4)|(col[4]<<3)|(col[5]<<2)|(col[6]<<1)|(col[7]<<0))
//Pin connected to DS of 74HC595
int SER = 10;
//Pin connected to ST_CP of 74HC595
int RCK = 11;
//Pin connected to SH_CP of 74HC595
int SRCK = 12;
int row[8] = {
0, 0, 0, 0, 0, 0, 0, 0
int col[8] = {
byte screen[8] = {
volatile byte screenRow = 0;
volatile byte screenCol = 0;
// A counter to know what frame we're showing
int animationIndex = 0;
// 8x8 Point temporary array
byte brightnesses[64];
Timer1.initialize(100);
pinMode(RCK, OUTPUT);
pinMode(SRCK, OUTPUT);
pinMode(SER, OUTPUT);
Timer1.attachInterrupt(doubleBuffer);
void doubleBuffer() {
row[screenRow] = 0;
col[screenCol] = 1;
screenCol++;
if (screenCol >= 8) {
screenCol = 0;
screenRow++;
if (screenRow >= 8) {
screenRow = 0;
if ((screen[screenRow] >> screenCol) & B1 == B1) {
row[screenRow] = 1;
col[screenCol] = 0;
digitalWrite(RCK, LOW);
shiftOut(SER, SRCK, MSBFIRST, COL_DATA); //先选择列
shiftOut(SER, SRCK, MSBFIRST, ROW_DATA); //再送行数据
digitalWrite(RCK, HIGH);
UpdataDate();
void UpdataDate() {
if (animationIndex < animationFrames) {
for (int i = 0; i < 64; i++) {
int Dot = (animation[animationIndex][i / 4] >> (i % 4 * 2));
brightnesses[i] = (Dot & B1)||(Dot & B10);
screen[7-i / 8] |= (brightnesses[i] << (i % 8)) ;
delay(animationDelays[animationIndex]);
animationIndex ++;
if (animationIndex >= animationFrames) {
//restart animation index
animationIndex = 0;
for (int i = 0; i < 8; i++)
screen[i] = B0;
face.h:
int animationFrames = 2;
int animationDelays[] = { 1000, 1000 };
// Animation is designed for 8x8 pixels
uint8_t animation[][16] = {
{ 0x55, 0x55, 0x11, 0x44, 0x5, 0x50, 0x1, 0x40, 0x51, 0x45, 0x11, 0x44, 0x11, 0x44, 0x55, 0x55 },
{ 0x5, 0x50, 0x5, 0x50, 0x0, 0x0, 0x40, 0x1, 0x40, 0x1, 0x0, 0x0, 0x4, 0x10, 0x50, 0x5 }
程序下载地址:Face
程序运行结果:点阵模块显示笑脸和囧脸~
face.h文件通过点阵取模软件获得:
乒乓游戏程序下载地址:乒乓游戏
