EEPROM:get()
2015年7月14日 (二) 11:30Admin讨论 | 贡献的版本
EEPROM
get()
描述
从EEPROM中读取任何类型的数据或者对象。
语法
EEPROM.get(address, data)
参数
address: 读取的位置,从0开始 (int 整型)
data: 读取的数据,可以是一个基本类型(例如:float 浮点型)或者是一个自定义的结构体。
返回值
数据传递的引用
示例
#include <EEPROM.h>
struct MyObject{
  float field1;
  byte field2;
  char name[10];
void setup(){
  float f = 0.00f;   //Variable to store data read from EEPROM.
  int eeAddress = 0; //EEPROM address to start reading from
  Serial.begin( 9600 );
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print( "Read float from EEPROM: " );
  //Get the float data from the EEPROM at position 'eeAddress'
  EEPROM.get( eeAddress, f );
  Serial.println( f, 3 );  //This may print 'ovf, nan' if the data inside the EEPROM is not a valid float.
  // get() can be used with custom structures too.
  eeAddress = sizeof(float); //Move address to the next byte after float 'f'.
  MyObject customVar; //Variable to store custom object read from EEPROM.
  EEPROM.get( eeAddress, customVar );
  Serial.println( "Read custom object from EEPROM: " );
  Serial.println( customVar.field1 );
  Serial.println( customVar.field2 );
  Serial.println( customVar.name );
void loop(){ /* Empty loop */ }
返回EEPROM库
返回Arduino库菜单
