Cores:USBCore.cpp
2015年7月10日 (五) 19:37Admin讨论 | 贡献的版本
USBCore.cpp
/* Copyright (c) 2010, Peter Barrett
** Permission to use, copy, modify, and/or distribute this software for
** any purpose with or without fee is hereby granted, provided that the
** above copyright notice and this permission notice appear in all copies.
** THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
** WARRANTIES WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED
** WARRANTIES OF MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR
** BE LIABLE FOR ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES
** OR ANY DAMAGES WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS,
** WHETHER IN AN ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION,
** ARISING OUT OF OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS
** SOFTWARE.
#include "USBAPI.h"
#if defined(USBCON)
#define EP_TYPE_CONTROL				0x00
#define EP_TYPE_BULK_IN				0x81
#define EP_TYPE_BULK_OUT			0x80
#define EP_TYPE_INTERRUPT_IN		0xC1
#define EP_TYPE_INTERRUPT_OUT		0xC0
#define EP_TYPE_ISOCHRONOUS_IN		0x41
#define EP_TYPE_ISOCHRONOUS_OUT		0x40
/** Pulse generation counters to keep track of the number of milliseconds remaining for each pulse type */
#define TX_RX_LED_PULSE_MS 100
volatile u8 TxLEDPulse; /**< Milliseconds remaining for data Tx LED pulse */
volatile u8 RxLEDPulse; /**< Milliseconds remaining for data Rx LED pulse */
extern const u16 STRING_LANGUAGE[] PROGMEM;
extern const u8 STRING_PRODUCT[] PROGMEM;
extern const u8 STRING_MANUFACTURER[] PROGMEM;
extern const DeviceDescriptor USB_DeviceDescriptor PROGMEM;
extern const DeviceDescriptor USB_DeviceDescriptorA PROGMEM;
const u16 STRING_LANGUAGE[2] = {
	(3<<8) | (2+2),
	0x0409	// English
#ifndef USB_PRODUCT
// If no product is provided, use USB IO Board
#define USB_PRODUCT     "USB IO Board"
#endif
const u8 STRING_PRODUCT[] PROGMEM = USB_PRODUCT;
#if USB_VID == 0x2341
#  if defined(USB_MANUFACTURER)
#    undef USB_MANUFACTURER
#  endif
#  define USB_MANUFACTURER "Arduino LLC"
#elif USB_VID == 0x1b4f
#  endif
#  define USB_MANUFACTURER "SparkFun"
#elif !defined(USB_MANUFACTURER)
// Fall through to unknown if no manufacturer name was provided in a macro
#  define USB_MANUFACTURER "Unknown"
#endif
const u8 STRING_MANUFACTURER[] PROGMEM = USB_MANUFACTURER;
#ifdef CDC_ENABLED
#define DEVICE_CLASS 0x02
#else
#define DEVICE_CLASS 0x00
#endif
//	DEVICE DESCRIPTOR
const DeviceDescriptor USB_DeviceDescriptor =
	D_DEVICE(0x00,0x00,0x00,64,USB_VID,USB_PID,0x100,IMANUFACTURER,IPRODUCT,0,1);
const DeviceDescriptor USB_DeviceDescriptorA =
	D_DEVICE(DEVICE_CLASS,0x00,0x00,64,USB_VID,USB_PID,0x100,IMANUFACTURER,IPRODUCT,0,1);
volatile u8 _usbConfiguration = 0;
static inline void WaitIN(void)
	while (!(UEINTX & (1<<TXINI)))
static inline void ClearIN(void)
	UEINTX = ~(1<<TXINI);
static inline void WaitOUT(void)
	while (!(UEINTX & (1<<RXOUTI)))
static inline u8 WaitForINOrOUT()
	while (!(UEINTX & ((1<<TXINI)|(1<<RXOUTI))))
	return (UEINTX & (1<<RXOUTI)) == 0;
static inline void ClearOUT(void)
	UEINTX = ~(1<<RXOUTI);
void Recv(volatile u8* data, u8 count)
	while (count--)
		*data++ = UEDATX;
	RXLED1;					// light the RX LED
	RxLEDPulse = TX_RX_LED_PULSE_MS;
static inline u8 Recv8()
	return UEDATX;
static inline void Send8(u8 d)
	UEDATX = d;
static inline void SetEP(u8 ep)
	UENUM = ep;
static inline u8 FifoByteCount()
	return UEBCLX;
static inline u8 ReceivedSetupInt()
	return UEINTX & (1<<RXSTPI);
static inline void ClearSetupInt()
	UEINTX = ~((1<<RXSTPI) | (1<<RXOUTI) | (1<<TXINI));
static inline void Stall()
	UECONX = (1<<STALLRQ) | (1<<EPEN);
static inline u8 ReadWriteAllowed()
	return UEINTX & (1<<RWAL);
static inline u8 Stalled()
	return UEINTX & (1<<STALLEDI);
static inline u8 FifoFree()
	return UEINTX & (1<<FIFOCON);
static inline void ReleaseRX()
	UEINTX = 0x6B;	// FIFOCON=0 NAKINI=1 RWAL=1 NAKOUTI=0 RXSTPI=1 RXOUTI=0 STALLEDI=1 TXINI=1
static inline void ReleaseTX()
	UEINTX = 0x3A;	// FIFOCON=0 NAKINI=0 RWAL=1 NAKOUTI=1 RXSTPI=1 RXOUTI=0 STALLEDI=1 TXINI=0
static inline u8 FrameNumber()
	return UDFNUML;
u8 USBGetConfiguration(void)
	return _usbConfiguration;
#define USB_RECV_TIMEOUT
class LockEP
	u8 _sreg;
public:
	LockEP(u8 ep) : _sreg(SREG)
		cli();
		SetEP(ep & 7);
	~LockEP()
		SREG = _sreg;
//	Number of bytes, assumes a rx endpoint
u8 USB_Available(u8 ep)
	LockEP lock(ep);
	return FifoByteCount();
//	Non Blocking receive
//	Return number of bytes read
int USB_Recv(u8 ep, void* d, int len)
	if (!_usbConfiguration || len < 0)
		return -1;
	LockEP lock(ep);
	u8 n = FifoByteCount();
	len = min(n,len);
	n = len;
	u8* dst = (u8*)d;
	while (n--)
		*dst++ = Recv8();
	if (len && !FifoByteCount())	// release empty buffer
		ReleaseRX();
	return len;
//	Recv 1 byte if ready
int USB_Recv(u8 ep)
	u8 c;
	if (USB_Recv(ep,&c,1) != 1)
		return -1;
	return c;
//	Space in send EP
u8 USB_SendSpace(u8 ep)
	LockEP lock(ep);
	if (!ReadWriteAllowed())
		return 0;
	return 64 - FifoByteCount();
//	Blocking Send of data to an endpoint
int USB_Send(u8 ep, const void* d, int len)
	if (!_usbConfiguration)
		return -1;
	int r = len;
	const u8* data = (const u8*)d;
	u8 timeout = 250;		// 250ms timeout on send? TODO
	while (len)
		u8 n = USB_SendSpace(ep);
		if (n == 0)
			if (!(--timeout))
				return -1;
			delay(1);
			continue;
		if (n > len)
			n = len;
			LockEP lock(ep);
			// Frame may have been released by the SOF interrupt handler
				continue;
			len -= n;
			if (ep & TRANSFER_ZERO)
				while (n--)
					Send8(0);
			else if (ep & TRANSFER_PGM)
				while (n--)
					Send8(pgm_read_byte(data++));
			else
				while (n--)
					Send8(*data++);
			if (!ReadWriteAllowed() || ((len == 0) && (ep & TRANSFER_RELEASE)))	// Release full buffer
				ReleaseTX();
	TXLED1;					// light the TX LED
	TxLEDPulse = TX_RX_LED_PULSE_MS;
	return r;
extern const u8 _initEndpoints[] PROGMEM;
const u8 _initEndpoints[] =
	0,
#ifdef CDC_ENABLED
	EP_TYPE_INTERRUPT_IN,		// CDC_ENDPOINT_ACM
	EP_TYPE_BULK_OUT,			// CDC_ENDPOINT_OUT
	EP_TYPE_BULK_IN,			// CDC_ENDPOINT_IN
#endif
#ifdef HID_ENABLED
	EP_TYPE_INTERRUPT_IN		// HID_ENDPOINT_INT
#endif
#define EP_SINGLE_64 0x32	// EP0
#define EP_DOUBLE_64 0x36	// Other endpoints
static
void InitEP(u8 index, u8 type, u8 size)
	UENUM = index;
	UECONX = 1;
	UECFG0X = type;
	UECFG1X = size;
static
void InitEndpoints()
	for (u8 i = 1; i < sizeof(_initEndpoints); i++)
		UENUM = i;
		UECONX = 1;
		UECFG0X = pgm_read_byte(_initEndpoints+i);
		UECFG1X = EP_DOUBLE_64;
	UERST = 0x7E;	// And reset them
	UERST = 0;
//	Handle CLASS_INTERFACE requests
static
bool ClassInterfaceRequest(Setup& setup)
	u8 i = setup.wIndex;
#ifdef CDC_ENABLED
	if (CDC_ACM_INTERFACE == i)
		return CDC_Setup(setup);
#endif
#ifdef HID_ENABLED
	if (HID_INTERFACE == i)
		return HID_Setup(setup);
#endif
	return false;
int _cmark;
int _cend;
void InitControl(int end)
	SetEP(0);
	_cmark = 0;
	_cend = end;
static
bool SendControl(u8 d)
	if (_cmark < _cend)
		if (!WaitForINOrOUT())
			return false;
		Send8(d);
		if (!((_cmark + 1) & 0x3F))
			ClearIN();	// Fifo is full, release this packet
	_cmark++;
	return true;
//	Clipped by _cmark/_cend
int USB_SendControl(u8 flags, const void* d, int len)
	int sent = len;
	bool pgm = flags & TRANSFER_PGM;
	while (len--)
		u8 c = pgm ? pgm_read_byte(data++) : *data++;
		if (!SendControl(c))
			return -1;
	return sent;
// Send a USB descriptor string. The string is stored in PROGMEM as a
// plain ASCII string but is sent out as UTF-16 with the correct 2-byte
// prefix
static bool USB_SendStringDescriptor(const u8*string_P, u8 string_len) {
        SendControl(2 + string_len * 2);
        SendControl(3);
        for(u8 i = 0; i < string_len; i++) {
                bool r = SendControl(pgm_read_byte(&string_P[i]));
                r &= SendControl(0); // high byte
                if(!r) {
                        return false;
        return true;
//	Does not timeout or cross fifo boundaries
//	Will only work for transfers <= 64 bytes
//	TODO
int USB_RecvControl(void* d, int len)
	WaitOUT();
	Recv((u8*)d,len);
	ClearOUT();
	return len;
int SendInterfaces()
	int total = 0;
	u8 interfaces = 0;
#ifdef CDC_ENABLED
	total = CDC_GetInterface(&interfaces);
#endif
#ifdef HID_ENABLED
	total += HID_GetInterface(&interfaces);
#endif
	return interfaces;
//	Construct a dynamic configuration descriptor
//	This really needs dynamic endpoint allocation etc
//	TODO
static
bool SendConfiguration(int maxlen)
	//	Count and measure interfaces
	InitControl(0);
	int interfaces = SendInterfaces();
	ConfigDescriptor config = D_CONFIG(_cmark + sizeof(ConfigDescriptor),interfaces);
	//	Now send them
	InitControl(maxlen);
	USB_SendControl(0,&config,sizeof(ConfigDescriptor));
	SendInterfaces();
	return true;
u8 _cdcComposite = 0;
static
bool SendDescriptor(Setup& setup)
	u8 t = setup.wValueH;
	if (USB_CONFIGURATION_DESCRIPTOR_TYPE == t)
		return SendConfiguration(setup.wLength);
	InitControl(setup.wLength);
#ifdef HID_ENABLED
	if (HID_REPORT_DESCRIPTOR_TYPE == t)
		return HID_GetDescriptor(t);
#endif
	const u8* desc_addr = 0;
	if (USB_DEVICE_DESCRIPTOR_TYPE == t)
		if (setup.wLength == 8)
			_cdcComposite = 1;
		desc_addr = _cdcComposite ?  (const u8*)&USB_DeviceDescriptorA : (const u8*)&USB_DeviceDescriptor;
	else if (USB_STRING_DESCRIPTOR_TYPE == t)
		if (setup.wValueL == 0) {
			desc_addr = (const u8*)&STRING_LANGUAGE;
		else if (setup.wValueL == IPRODUCT) {
			return USB_SendStringDescriptor(STRING_PRODUCT, strlen(USB_PRODUCT));
		else if (setup.wValueL == IMANUFACTURER) {
			return USB_SendStringDescriptor(STRING_MANUFACTURER, strlen(USB_MANUFACTURER));
		else
			return false;
	if (desc_addr == 0)
		return false;
	u8 desc_length = pgm_read_byte(desc_addr);
	USB_SendControl(TRANSFER_PGM,desc_addr,desc_length);
	return true;
//	Endpoint 0 interrupt
ISR(USB_COM_vect)
    SetEP(0);
	if (!ReceivedSetupInt())
		return;
	Setup setup;
	Recv((u8*)&setup,8);
	ClearSetupInt();
	u8 requestType = setup.bmRequestType;
	if (requestType & REQUEST_DEVICETOHOST)
		WaitIN();
	else
		ClearIN();
    bool ok = true;
	if (REQUEST_STANDARD == (requestType & REQUEST_TYPE))
		//	Standard Requests
		u8 r = setup.bRequest;
		if (GET_STATUS == r)
			Send8(0);		// TODO
			Send8(0);
		else if (CLEAR_FEATURE == r)
		else if (SET_FEATURE == r)
		else if (SET_ADDRESS == r)
			WaitIN();
			UDADDR = setup.wValueL | (1<<ADDEN);
		else if (GET_DESCRIPTOR == r)
			ok = SendDescriptor(setup);
		else if (SET_DESCRIPTOR == r)
			ok = false;
		else if (GET_CONFIGURATION == r)
			Send8(1);
		else if (SET_CONFIGURATION == r)
			if (REQUEST_DEVICE == (requestType & REQUEST_RECIPIENT))
				InitEndpoints();
				_usbConfiguration = setup.wValueL;
			} else
				ok = false;
		else if (GET_INTERFACE == r)
		else if (SET_INTERFACE == r)
	else
		InitControl(setup.wLength);		//	Max length of transfer
		ok = ClassInterfaceRequest(setup);
	if (ok)
		ClearIN();
	else
		Stall();
void USB_Flush(u8 ep)
	SetEP(ep);
	if (FifoByteCount())
		ReleaseTX();
//	General interrupt
ISR(USB_GEN_vect)
	u8 udint = UDINT;
	UDINT = 0;
	//	End of Reset
	if (udint & (1<<EORSTI))
		InitEP(0,EP_TYPE_CONTROL,EP_SINGLE_64);	// init ep0
		_usbConfiguration = 0;			// not configured yet
		UEIENX = 1 << RXSTPE;			// Enable interrupts for ep0
	//	Start of Frame - happens every millisecond so we use it for TX and RX LED one-shot timing, too
	if (udint & (1<<SOFI))
#ifdef CDC_ENABLED
		USB_Flush(CDC_TX);				// Send a tx frame if found
#endif
		// check whether the one-shot period has elapsed.  if so, turn off the LED
		if (TxLEDPulse && !(--TxLEDPulse))
			TXLED0;
		if (RxLEDPulse && !(--RxLEDPulse))
			RXLED0;
//	VBUS or counting frames
//	Any frame counting?
u8 USBConnected()
	u8 f = UDFNUML;
	delay(3);
	return f != UDFNUML;
USBDevice_ USBDevice;
USBDevice_::USBDevice_()
void USBDevice_::attach()
	UHWCON = 0x01;						// power internal reg
	USBCON = (1<<USBE)|(1<<FRZCLK);		// clock frozen, usb enabled
#if F_CPU == 16000000UL
	PLLCSR = 0x12;						// Need 16 MHz xtal
#elif F_CPU == 8000000UL
	PLLCSR = 0x02;						// Need 8 MHz xtal
#endif
	while (!(PLLCSR & (1<<PLOCK)))		// wait for lock pll
	// Some tests on specific versions of macosx (10.7.3), reported some
	// strange behaviuors when the board is reset using the serial
	// port touch at 1200 bps. This delay fixes this behaviour.
	delay(1);
	USBCON = ((1<<USBE)|(1<<OTGPADE));	// start USB clock
	UDIEN = (1<<EORSTE)|(1<<SOFE);		// Enable interrupts for EOR (End of Reset) and SOF (start of frame)
	UDCON = 0;							// enable attach resistor
	TX_RX_LED_INIT;
void USBDevice_::detach()
//	Check for interrupts
//	TODO: VBUS detection
bool USBDevice_::configured()
void USBDevice_::poll()
#endif /* if defined(USBCON) */
返回核心代码首页
