LEGO-声音传感器
- 信号类型:模拟输入
- 接口类型:PH2.0-4P
- 外形尺寸:单位mm
- Arduino UNO
- Arduino UNO 专用扩展板
- 声音传感器
- 食人鱼模块
- 线材
Arduino IDE示例代码复制代码至Arduino IDE中编译上传 int sensorPin = A3; // select the input pin for the sound sensor int ledPin = 5; // select the pin for the LED void setup() { pinMode(ledPin, OUTPUT); Serial.begin(9600); } void loop() { int sensorValue = analogRead(sensorPin); // read the value from the sensor Serial.println(sensorValue); // if the sound sensor’s value is greater than 200, the led will be on for 2 seconds. // Otherwise, the led will be turned off if (sensorValue > 200) { digitalWrite(ledPin, HIGH); // turn the ledPin on delay(2000); } else { digitalWrite(ledPin, LOW); // turn the ledPin off } } |
Mixly示例代码
Mind+示例代码Mind+ 1.7 |
当摇杆动作有变化时,输出相应数据,如下图:
