Cores:Stream.cpp
2015年7月10日 (五) 19:35Admin讨论 | 贡献的版本
Stream.cpp
 Stream.cpp - adds parsing methods to Stream class
 Copyright (c) 2008 David A. Mellis.  All right reserved.
 This library is free software; you can redistribute it and/or
 modify it under the terms of the GNU Lesser General Public
 License as published by the Free Software Foundation; either
 version 2.1 of the License, or (at your option) any later version.
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 Lesser General Public License for more details.
 You should have received a copy of the GNU Lesser General Public
 License along with this library; if not, write to the Free Software
 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
 Created July 2011
 parsing functions based on TextFinder library by Michael Margolis
 findMulti/findUntil routines written by Jim Leonard/Xuth
#include "Arduino.h"
#include "Stream.h"
#define PARSE_TIMEOUT 1000  // default number of milli-seconds to wait
#define NO_SKIP_CHAR  1  // a magic char not found in a valid ASCII numeric field
// private method to read stream with timeout
int Stream::timedRead()
  int c;
  _startMillis = millis();
  do {
    c = read();
    if (c >= 0) return c;
  } while(millis() - _startMillis < _timeout);
  return -1;     // -1 indicates timeout
// private method to peek stream with timeout
int Stream::timedPeek()
  int c;
  do {
    c = peek();
// returns peek of the next digit in the stream or -1 if timeout
// discards non-numeric characters
int Stream::peekNextDigit()
  int c;
  while (1) {
    c = timedPeek();
    if (c < 0) return c;  // timeout
    if (c == '-') return c;
    if (c >= '0' && c <= '9') return c;
    read();  // discard non-numeric
// Public Methods
void Stream::setTimeout(unsigned long timeout)  // sets the maximum number of milliseconds to wait
  _timeout = timeout;
 // find returns true if the target string is found
bool  Stream::find(char *target)
  return findUntil(target, strlen(target), NULL, 0);
// reads data from the stream until the target string of given length is found
// returns true if target string is found, false if timed out
bool Stream::find(char *target, size_t length)
  return findUntil(target, length, NULL, 0);
// as find but search ends if the terminator string is found
bool  Stream::findUntil(char *target, char *terminator)
  return findUntil(target, strlen(target), terminator, strlen(terminator));
// reads data from the stream until the target string of the given length is found
// search terminated if the terminator string is found
// returns true if target string is found, false if terminated or timed out
bool Stream::findUntil(char *target, size_t targetLen, char *terminator, size_t termLen)
  if (terminator == NULL) {
    MultiTarget t[1] = {{target, targetLen, 0}};
    return findMulti(t, 1) == 0 ? true : false;
    MultiTarget t[2] = {{target, targetLen, 0}, {terminator, termLen, 0}};
    return findMulti(t, 2) == 0 ? true : false;
// returns the first valid (long) integer value from the current position.
// initial characters that are not digits (or the minus sign) are skipped
// function is terminated by the first character that is not a digit.
long Stream::parseInt()
  return parseInt(NO_SKIP_CHAR); // terminate on first non-digit character (or timeout)
// as above but a given skipChar is ignored
// this allows format characters (typically commas) in values to be ignored
long Stream::parseInt(char skipChar)
  bool isNegative = false;
  long value = 0;
  int c;
  c = peekNextDigit();
  // ignore non numeric leading characters
  if(c < 0)
    return 0; // zero returned if timeout
  do{
    if(c == skipChar)
      ; // ignore this charactor
    else if(c == '-')
      isNegative = true;
    else if(c >= '0' && c <= '9')        // is c a digit?
      value = value * 10 + c - '0';
    read();  // consume the character we got with peek
    c = timedPeek();
  while( (c >= '0' && c <= '9') || c == skipChar );
  if(isNegative)
    value = -value;
  return value;
// as parseInt but returns a floating point value
float Stream::parseFloat()
  return parseFloat(NO_SKIP_CHAR);
// as above but the given skipChar is ignored
float Stream::parseFloat(char skipChar){
  bool isFraction = false;
  long value = 0;
  char c;
  float fraction = 1.0;
  if(c < 0)
  do{
    if(c == skipChar)
      ; // ignore
    else if(c == '-')
      isNegative = true;
    else if (c == '.')
      isFraction = true;
    else if(c >= '0' && c <= '9')  {      // is c a digit?
      if(isFraction)
         fraction *= 0.1;
    c = timedPeek();
  while( (c >= '0' && c <= '9')  || c == '.' || c == skipChar );
  if(isNegative)
    value = -value;
  if(isFraction)
    return value * fraction;
  else
    return value;
// read characters from stream into buffer
// terminates if length characters have been read, or timeout (see setTimeout)
// returns the number of characters placed in the buffer
// the buffer is NOT null terminated.
size_t Stream::readBytes(char *buffer, size_t length)
  size_t count = 0;
  while (count < length) {
    int c = timedRead();
    if (c < 0) break;
    *buffer++ = (char)c;
    count++;
  return count;
// as readBytes with terminator character
// terminates if length characters have been read, timeout, or if the terminator character  detected
// returns the number of characters placed in the buffer (0 means no valid data found)
size_t Stream::readBytesUntil(char terminator, char *buffer, size_t length)
  if (length < 1) return 0;
  size_t index = 0;
  while (index < length) {
    if (c < 0 || c == terminator) break;
    index++;
  return index; // return number of characters, not including null terminator
String Stream::readString()
  String ret;
  while (c >= 0)
    ret += (char)c;
    c = timedRead();
  return ret;
String Stream::readStringUntil(char terminator)
  String ret;
  while (c >= 0 && c != terminator)
    ret += (char)c;
    c = timedRead();
  return ret;
int Stream::findMulti( struct Stream::MultiTarget *targets, int tCount) {
  // any zero length target string automatically matches and would make
  // a mess of the rest of the algorithm.
  for (struct MultiTarget *t = targets; t < targets+tCount; ++t) {
    if (t->len <= 0)
      return t - targets;
  while (1) {
    if (c < 0)
      return -1;
      // the simple case is if we match, deal with that first.
      if (c == t->str[t->index]) {
        if (++t->index == t->len)
          return t - targets;
        else
          continue;
      // if not we need to walk back and see if we could have matched further
      // down the stream (ie '1112' doesn't match the first position in '11112'
      // but it will match the second position so we can't just reset the current
      // index to 0 when we find a mismatch.
      if (t->index == 0)
        continue;
      int origIndex = t->index;
      do {
        --t->index;
        // first check if current char works against the new current index
        if (c != t->str[t->index])
          continue;
        // if it's the only char then we're good, nothing more to check
        if (t->index == 0) {
          t->index++;
          break;
        // otherwise we need to check the rest of the found string
        int diff = origIndex - t->index;
        size_t i;
        for (i = 0; i < t->index; ++i) {
          if (t->str[i] != t->str[i + diff])
            break;
        // if we successfully got through the previous loop then our current
        // index is good.
        if (i == t->index) {
          t->index++;
          break;
        // otherwise we just try the next index
      } while (t->index);
  // unreachable
  return -1;
返回核心代码首页
