彩色LED模块 - 1位
- 色彩显示:16777216种颜色的全真色彩显示
- 亮度调节:256级亮度调节
- 扫描频率:>=400Hz/s
- 数据传输速率:800Kbps
- 模块尺寸:28*21*7.3MM (长*宽*高)
- 模块重量:2.6g
#include <Adafruit_NeoPixel.h> #define Red Color(255,0,0) #define Green Color(0,255,0) #define Blue Color(0,0,255) #define PIN 5 #define NUMPIXELS 1 // Parameter 1 = number of pixels in strip // Parameter 2 = pin number (most are valid) // Parameter 3 = pixel type flags, add together as needed: // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs) // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers) // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products) // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800); int delayval = 500; // delay for half a second void setup() { // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket #if defined (__AVR_ATtiny85__) if (F_CPU == 16000000) clock_prescale_set(clock_div_1); #endif // End of trinket special code pixels.begin(); // This initializes the NeoPixel library. pixels.show(); } void loop() { lightLED(pixels.Red); //Order lit the red light lightLED(pixels.Green); //Order lit the green light lightLED(pixels.Blue); //Order lit the blue light } void lightLED(uint32_t c) { // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one. for (int i = 0; i < NUMPIXELS; i++) { // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255 pixels.setPixelColor(i, c); // Moderately bright green color. pixels.show(); // This sends the updated pixel color to the hardware. delay(delayval); // Delay for a period of time (in milliseconds). } }
程序下载地址:simpleExample_ColorLED
程序演示效果地址:LED模块演示视频
- WS2812说明书-英文 备用地址
- WS2812说明书-中文 备用地址
- Arduino-WS2812库-FastLED
