欧姆龙按键开关模块
欧姆龙按键模块按下时,输出低电平;释放时,输出高电平。
- 工作湿度:35~85%RH(+5~+35℃)
- 接点结构:1A常开接点
- 接触阻值:100mΩ以下
- 绝缘阻值:100MΩ以上
- 使用寿命:1000万次以上
- 模块尺寸:28*21*15.8MM(长*宽*高)
- 模块重量:3.8g
示例一:按键控制LED
- 电路连接
- 欧姆龙按键模块的 G、V、S分别连接 Arduino UNO的GND、VCC(+5V)、D2引脚。
Button_switch
按键开关:按一次按键,点亮LED,再按一次按键,熄灭LED
www.yfrobot.com
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 10; // the number of the LED pin
boolean ledState = false; // 记录LED状态
boolean buttonState = true; // 记录按键状态
void setup ()
pinMode(buttonPin, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// 等待按键按下
while (buttonState == HIGH) {}
// 当按键按下时,点亮或熄灭LED
if (ledState == true) {
digitalWrite(ledPin, LOW);
ledState = !ledState;
digitalWrite(ledPin, HIGH);
delay(500);
程序下载地址:
程序运行结果:按下按键,点亮LED,释放按键,熄灭LED。
示例二:按键控制无源蜂鸣器发声
- 电路连接
//button test
int buzzerPin = 6;
int buttonState = 0;
int buttonVal[5];
void setup ()
pinMode(buzzerPin,OUTPUT);
for(int i = 0;i < 5;i++){
buttonState = buttonPin[i];
switch(buttonState){
case 8: makeSound(1); break;
case 9: makeSound(2); break;
case 10: makeSound(3); break;
case 11: makeSound(4); break;
case 12: makeSound(5); break;
buttonState = 0;
// s value: 1 - 7
void makeSound(int s){
tone(buzzerPin,notes_D[s-1]);
delay(400);
noTone(buzzerPin);
程序下载地址:buttonTest
程序演示视频:button
