PROGMEM
Store data in flash (program) memory instead of SRAM. There's a description of the various types of memory available on an Arduino board.
The PROGMEM keyword is a variable modifier, it should be used only with the datatypes defined in pgmspace.h. It tells the compiler "put this information into flash memory", instead of into SRAM, where it would normally go.
PROGMEM is part of the pgmspace.h library that is available in the AVR architecture only. So you first need to include the library at the top your sketch, like this:
#include <avr/pgmspace.h>
Syntax
const dataType variableName[] PROGMEM = {data0, data1, data3...};
- - dataType - any variable type
- - variableName - the name for your array of data
Note that because PROGMEM is a variable modifier, there is no hard and fast rule about where it should go, so the Arduino compiler accepts all of the definitions below, which are also synonymous. However experiments have indicated that, in various versions of Arduino (having to do with GCC version), PROGMEM may work in one location and not in another. The "string table" example below has been tested to work with Arduino 13. Earlier versions of the IDE may work better if PROGMEM is included after the variable name.
const dataType variableName[] PROGMEM = {}; // use this form
const PROGMEM dataType variableName[] = {}; // or this form
const dataType PROGMEM variableName[] = {}; // not this one
While PROGMEM could be used on a single variable, it is really only worth the fuss if you have a larger block of data that needs to be stored, which is usually easiest in an array, (or another C data structure beyond our present discussion).
Using PROGMEM is also a two-step procedure. After getting the data into Flash memory, it requires special methods (functions), also defined in the pgmspace.h library, to read the data from program memory back into SRAM, so we can do something useful with it.
Example
The following code fragments illustrate how to read and write chars (bytes) and ints (2 bytes) to PROGMEM.
// save some unsigned ints
const PROGMEM uint16_t charSet[] = { 65000, 32796, 16843, 10, 11234};
// save some chars
const char signMessage[] PROGMEM = {"I AM PREDATOR, UNSEEN COMBATANT. CREATED BY THE UNITED STATES DEPART"};
unsigned int displayInt;
int k; // counter variable
char myChar;
while (!Serial);
// read back a 2-byte int
for (k = 0; k < 5; k++)
displayInt = pgm_read_word_near(charSet + k);
Serial.println(displayInt);
Serial.println();
// read back a char
int len = strlen_P(signMessage);
for (k = 0; k < len; k++)
myChar = pgm_read_byte_near(signMessage + k);
Serial.print(myChar);
Serial.println();
Arrays of strings
It is often convenient when working with large amounts of text, such as a project with an LCD display, to setup an array of strings. Because strings themselves are arrays, this is in actually an example of a two-dimensional array.
These tend to be large structures so putting them into program memory is often desirable. The code below illustrates the idea.
PROGMEM string demo
How to store a table of strings in program memory (flash),
and retrieve them.
Information summarized from:
http://www.nongnu.org/avr-libc/user-manual/pgmspace.html
Setting up a table (array) of strings in program memory is slightly complicated, but
here is a good template to follow.
Setting up the strings is a two-step process. First define the strings.
const char string_0[] PROGMEM = "String 0"; // "String 0" etc are strings to store - change to suit.
const char string_1[] PROGMEM = "String 1";
const char string_2[] PROGMEM = "String 2";
const char string_3[] PROGMEM = "String 3";
const char string_4[] PROGMEM = "String 4";
const char string_5[] PROGMEM = "String 5";
// Then set up a table to refer to your strings.
const char* const string_table[] PROGMEM = {string_0, string_1, string_2, string_3, string_4, string_5};
char buffer[30]; // make sure this is large enough for the largest string it must hold
while(!Serial);
Serial.println("OK");
/* Using the string table in program memory requires the use of special functions to retrieve the data.
The strcpy_P function copies a string from program space to a string in RAM ("buffer").
Make sure your receiving string in RAM is large enough to hold whatever
you are retrieving from program space. */
for (int i = 0; i < 6; i++)
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
Serial.println(buffer);
delay( 500 );
Note
Please note that variables must be either globally defined, OR defined with the static keyword, in order to work with PROGMEM.
The following code will NOT work when inside a function:
const char long_str[] PROGMEM = "Hi, I would like to tell you a bit about myself.\n";
The following code WILL work, even if locally defined within a function:
const static char long_str[] PROGMEM = "Hi, I would like to tell you a bit about myself.\n"
The F() macro
示例
示例
if (a >= 10 && a <= 20){} // true if a is between 10 and 20
