8*8点阵模块
- 供电电压:DC5V
- 使用芯片:74HC595
- 模块尺寸:32.5*32.5*14.7MM(长*宽*高)
- 模块重量:10.6g
- 1. VCC -- Vcc(电源+5V)
- 2. GND -- Gnd(地)
- 3. SER -- 串行移位输入
- 4. RCK -- 存储寄存器的时序输入
- 5. SRCK -- 移位寄存器的时序输入
点阵模块 | Arduino UNO |
VCC | +5V |
GND | GND |
SER | D10 |
RCK | D11 |
SRCK | D12 |
示例一:基本显示
Face.ino:
/************************************************** Face ( 8x8 Led Dot Matrix with two 74HC595 on Arduino) by YFROBOT ***************************************************/ #include "TimerOne.h" #include "face.h" // 默认显示 #define ROW_DATA ((row[0]<<7)|(row[1]<<6)|(row[2]<<5)|(row[3]<<4)|(row[4]<<3)|(row[5]<<2)|(row[6]<<1)|(row[7]<<0)) #define COL_DATA ((col[0]<<7)|(col[1]<<6)|(col[2]<<5)|(col[3]<<4)|(col[4]<<3)|(col[5]<<2)|(col[6]<<1)|(col[7]<<0)) // 垂直翻转 //#define ROW_DATA ((row[0]<<0)|(row[1]<<1)|(row[2]<<2)|(row[3]<<3)|(row[4]<<4)|(row[5]<<5)|(row[6]<<6)|(row[7]<<7)) //#define COL_DATA ((col[0]<<0)|(col[1]<<1)|(col[2]<<2)|(col[3]<<3)|(col[4]<<4)|(col[5]<<5)|(col[6]<<6)|(col[7]<<7)) // flip horizontal #define flip_horizontal 7-screenCol // 默认显示 //#define flip_horizontal screenCol // 水平翻转 //Pin connected to DS of 74HC595 int SER = 10; //Pin connected to ST_CP of 74HC595 int RCK = 11; //Pin connected to SH_CP of 74HC595 int SRCK = 12; int row[8] = { 0, 0, 0, 0, 0, 0, 0, 0 }; int col[8] = { 0, 0, 0, 0, 0, 0, 0, 0 }; byte screen[8] = { 0, 0, 0, 0, 0, 0, 0, 0 }; volatile byte screenRow = 0; volatile byte screenCol = 0; // A counter to know what frame we're showing int animationIndex = 0; // 8x8 Point temporary array byte brightnesses[64]; void setup() { // Timer1.initialize(100); pinMode(RCK, OUTPUT); pinMode(SRCK, OUTPUT); pinMode(SER, OUTPUT); // Timer1.attachInterrupt(doubleBuffer); Serial.begin(9600); } void doubleBuffer() { int k = 8; while (k--) { row[screenRow] = 0; col[screenCol] = 1; screenCol++; if (screenCol >= 8) { screenCol = 0; screenRow++; if (screenRow >= 8) { screenRow = 0; } } if ((screen[screenRow] >> flip_horizontal) & B1 == B1) { row[screenRow] = 1; col[screenCol] = 0; digitalWrite(RCK, LOW); shiftOut(SER, SRCK, MSBFIRST, COL_DATA); //先选择列 shiftOut(SER, SRCK, MSBFIRST, ROW_DATA); //再送行数据 digitalWrite(RCK, HIGH); } } } void UpdataDate() { if (animationIndex < animationFrames) { for (int i = 0; i < 64; i++) { int Dot = (animation[animationIndex][i / 4] >> (i % 4 * 2)); brightnesses[i] = (Dot & B1) || (Dot & B10); screen[7 - i / 8] |= (brightnesses[i] << (i % 8)) ; } } unsigned long startime = millis(); while (millis() - startime < animationDelays[animationIndex]) { doubleBuffer(); } animationIndex ++; if (animationIndex >= animationFrames) { //restart animation index animationIndex = 0; } for (int i = 0; i < 8; i++) screen[i] = B0; } void loop() { UpdataDate(); }
face.h:
int animationFrames = 2; int animationDelays[] = { 1000, 1000 }; // Animation is designed for 8x8 pixels uint8_t animation[][16] = { { 0x55, 0x55, 0x11, 0x44, 0x5, 0x50, 0x1, 0x40, 0x51, 0x45, 0x11, 0x44, 0x11, 0x44, 0x55, 0x55 }, { 0x5, 0x50, 0x5, 0x50, 0x0, 0x0, 0x40, 0x1, 0x40, 0x1, 0x0, 0x0, 0x4, 0x10, 0x50, 0x5 } };
程序下载地址:Face
程序运行结果:点阵模块显示笑脸和囧脸~
face.h文件通过点阵取模软件 获得:
点阵模块滚屏显示,请移步:点阵模块滚屏显示
乒乓游戏程序下载地址:乒乓游戏
