Digispark控制板使用
[隐藏]连接并使用digispark
Bootloader:
The bootloader is the code that is pre-programmed on your Digispark and allows it to act as a USB device so that it can be programmed by the Arduino IDE.
The Digispark runs the “micronucleus tiny85” bootloader version 1.02, an open source project: https://github.com/micronucleus/micronucleus originally written by Bluebie: https://github.com/Bluebie.
CAUTION We are not at this point supporting upgrading the firmware, so if you decide to, you do so entirely at your own risk.
Software:
The Digispark uses the Arduino IDE 1.6.5+ (Arduino 1.6.5r2 - NOT 1.6.6 or 1.6.7 strongly recommended)
安装说明
windows install
- 首先下载arduino IDE :http://www.arduino.cc/en/Main/Software (1.6.5以上版本)
- 双击运行arduino IDE, file -> preferences
- 在 Additional Boards Manager URLs 输入框中填写:http://digistump.com/package_digistump_index.json,点击OK
- Tools -> Boad -> Boards Manager,type选择 "Contributed",之后选择"Digistump AVR Boards" 安装包,点击"Install"按钮进行安装
- 等待下载安装完成后,会显示"Installed";完成后,Tools -> Boards ->Digispark(Default - 16.5mhz),新用户建议选择该项。
- 安装完成
Linux Install
- If you haven't before - Install the udev rules found here:Troubleshooting section
下载程序测试
digispark 和其他arduino兼容产品不同,下面看看具体哪里不同?
- 板型选择:Tools -> Boards -> Digispark(Default - 16.5mhz) (Tools -> Programmer无需选择)
- 打开例程代码:File -> Examples -> Digispark_Examples -> Start (无需连接控制板),代码如下:
// the setup routine runs once when you press reset: void setup() { // initialize the digital pin as an output. pinMode(0, OUTPUT); //LED on Model B pinMode(1, OUTPUT); //LED on Model A } // the loop routine runs over and over again forever: void loop() { digitalWrite(0, HIGH); // turn the LED on (HIGH is the voltage level) digitalWrite(1, HIGH); delay(1000); // wait for a second digitalWrite(0, LOW); // turn the LED off by making the voltage LOW digitalWrite(1, LOW); delay(1000); // wait for a second }
- 点击"Upload"按钮,底部状态栏会提示要求连接digispark控制板,这时你需要将其插入(你有60s的时间将其连接上,不用着急)
- 插上Digispark控制板后,等待下载完成,底部状态栏会有提示,如下图:
- 程序下载完成后,它将立即运行代码
PS:如果你拔掉digispark并重新供电,程序将延时5秒运行。这5秒延时是确定你是否想要运行此程序。
