JsonParserExample
2016年8月22日 (一) 15:41Allblue讨论 | 贡献的版本
Json库
// Copyright Benoit Blanchon 2014-2016
// MIT License
// Arduino JSON library
// https://github.com/bblanchon/ArduinoJson
// If you like this project, please add a star!
#include <ArduinoJson.h>
  while (!Serial) {
    // wait serial port initialization
  // Memory pool for JSON object tree.-- 为JSON对象树创建内存池
  // Inside the brackets, 200 is the size of the pool in bytes,-- 200字节为内存是大小
  // If the JSON object is more complex, you need to increase that value. -- 如果JSON对象过于复杂,你需要更改这个内存大小
  StaticJsonBuffer<200> jsonBuffer;
  // StaticJsonBuffer allocates memory on the stack, it can be
  // replaced by DynamicJsonBuffer which allocates in the heap.
  //  -- StaticJsonBuffer 在栈上分配内存,它可以被在对上分配内存的DynamicJsonBuffer所代替
  // It's simpler but less efficient. -- DynamicJsonBuffer 简单但效率低
  // DynamicJsonBuffer  jsonBuffer;
  // JSON input string.  --  JSON 输入字符串
  // It's better to use a char[] as shown here. -- 最好使用一个char类型 如下所示
  // If you use a const char* or a String, ArduinoJson will
  // have to make a copy of the input in the JsonBuffer.
  //  -- 如果你使用 const char* 或 String, arduinoJson 将不得不使输入数据拷贝成JSON缓冲区数据
  char json[] =
      "{\"sensor\":\"gps\",\"time\":1351824120,\"data\":[48.756080,2.302038]}";
  // Root of the object tree. -- 对象树根
  // It's a reference to the JsonObject, the actual bytes are inside the
  // JsonBuffer with all the other nodes of the object tree.
  //  -- 这是对JsonObject参考,实际字节是JSONBuffer内的对象树的所有其他节点
  // Memory is freed when jsonBuffer goes out of scope. -- jsonBuffer超出范围时内存已经被释放了
  JsonObject& root = jsonBuffer.parseObject(json);
  // Test if parsing succeeds. -- 测试是否解析成功
  if (!root.success()) {
    Serial.println("parseObject() failed");
    return;
  // Fetch values. -- 取值
  // Most of the time, you can rely on the implicit casts.
  // In other case, you can do root["time"].as<long>();
  const char* sensor = root["sensor"];
  long time = root["time"];
  double latitude = root["data"][0];
  double longitude = root["data"][1];
  // Print values.  -- 打印值
  Serial.println(sensor);
  Serial.println(time);
  Serial.println(latitude, 6);
  Serial.println(longitude, 6);
  // not used in this example
返回Arduino库菜单
