SD库
2015年7月21日 (二) 09:18Admin讨论 | 贡献的版本
Examples
The SD class provides functions for accessing the SD card and manipulating its files and directories.
- Datalogger: Log data from three analog sensors to a SD card using the SD library
- DumpFile: Read a file from a SD card using the SD library and send it over the serial port
- Files: Create and destroy a file on a SD card
- ReadWrite: Read and write data to and from a file on a SD card
- CardInfo: Get information about a SD card
SD Class
- begin()
- exists()
- mkdir()
- open()
- remove()
- rmdir()
File class
The File class allows for reading from and writing to individual files on the SD card.
- available()
- close()
- flush()
- peek()
- position()
- print
- println()
- seek()
- size()
- read()
- write()
- isDirectory()
- openNextFile()
- rewindDirectory()
返回Arduino库菜单
