Micro:Bit Valon-I en
2021年1月11日 (一) 16:48Allblue讨论 | 贡献的版本
Valon-I Microbit
Introduction
Function
Parameters
  • One-key start switch x1
  • Power indicator x1
  • Buzzer x1
  • N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Motor Control
RGB LED Control
Fittings: RGB LED module x 1
Installation:
Read Infrared Key
Installation:
IR Remote Control
Installation: ditto.
Line tracking
Read Ultrasonic Distance
Installation:
Ultrasonic Obstacle-avoiding
Installation:ditto.
Back to homepage
More suggestions and questions welcome feedback to YFRobot Forum
