Motor:Bit
2020年12月21日 (一) 10:13Allblue讨论 | 贡献的版本
MotorBit
This YFROBOT Motor:Bit expansion was developed by YFROBOT.
The YFROBOT Motor:Bit is an integrated motor driver and breakout board for the BBC micro:bit. With two integrated motor driver chip DRV8838, your micro:bit can drive two DC motors with 250mA max single channel current.
The Motor:Bit also features the “GVS” connectors, allowing for easy direct connection to compatible “GVS” sensors and outputs. Among these connectors, P0, P1 support sensors with 3.3V power voltage only; P2, P8, support 3.3V or 5V sensors, You can change the output voltage by jumper caps on the board.
YFROBOT的YFROBOT Motor:Bit擴展產品。
YFROBOT Motor:Bit是BBC micro:bit的集成電動機驅動器和分線板。使用兩個集成的電動機驅動器芯片DRV8838,您的micro:bit可以驅動最大250mA單通道電流的兩個直流電動機。
Motor:Bit還具有“ GVS”連接器,可輕鬆直接連接至兼容的“ GVS”傳感器和輸出。在這些連接器中,P0,P1僅支持電源電壓為3.3V的傳感器。 P2,P8,支持3.3V或5V傳感器,您可以通過板上的跳線帽更改輸出電壓。
Joystick_mocribt_logo
JoyStick_MicroBit
YFROBOT JoyStick for Micro:Bit
官方购买途径:企业店铺JoyStick for Micro:Bit
Introduction
JoyStick is a programmable remote controller specially designed for maker education and adapted to Micro:Bit. It supports multiple programming environments such as MakeCode, Scratch and Python; it has the advantages of flexibility and exquisiteness, easy to use, and a variety of interesting functions. It can cultivate and develop children's logical thinking ability in a relaxed and happy situation, and help improve learning interest.
JoyStick programmable remote control handle, equipped with 4 high-quality buttons, 1 joystick, 1 vibration motor, 1 buzzer, 4 programmable RGB LEDs, power indicator LED, lithium battery power supply, visual power charging system, power dial Move the switch; and extend 2 3PGVS standard sensor interface, 1 I2C interface, strong expandability.
Function
Parameters
  • Supply voltage: 3.7V DC
  • Power switch x1
  • Power indicator x1
  • Rocker x1
  • Button x4
  • Vibration motor x1
  • Buzzer x1
  • RGBLED lights x4
  • Reserved expansion port 3P interface (GVS) x2 (default unwelded port)
  • Reserved expansion port I2C interface x1 (default is not welded port)
  • Charging time: ~ 60 minutes
  • Use time: ~ 20 hours
Dimensions and weight
Product size: 155mm x 56mm x 32mm (height, including joystick); weight: 63.5g (excluding microbit)
Control the Valon-I
Required hardware: Micro:Bit control board x2, micro usb line x1, JoyStick remote control handle x1,Valon-I x 1
Back to homepage
