Motor:Bit
2020年12月21日 (一) 10:12Allblue讨论 | 贡献的版本
按键模块
This YFROBOT Motor:Bit expansion was developed by YFROBOT.
The YFROBOT Motor:Bit is an integrated motor driver and breakout board for the BBC micro:bit. With two integrated motor driver chip DRV8838, your micro:bit can drive two DC motors with 250mA max single channel current.
The Motor:Bit also features the “GVS” connectors, allowing for easy direct connection to compatible “GVS” sensors and outputs. Among these connectors, P0, P1 support sensors with 3.3V power voltage only; P2, P8, support 3.3V or 5V sensors, You can change the output voltage by jumper caps on the board.
YFROBOT的YFROBOT Motor:Bit擴展產品。
YFROBOT Motor:Bit是BBC micro:bit的集成電動機驅動器和分線板。使用兩個集成的電動機驅動器芯片DRV8838,您的micro:bit可以驅動最大250mA單通道電流的兩個直流電動機。
Motor:Bit還具有“ GVS”連接器,可輕鬆直接連接至兼容的“ GVS”傳感器和輸出。在這些連接器中,P0,P1僅支持電源電壓為3.3V的傳感器。 P2,P8,支持3.3V或5V傳感器,您可以通過板上的跳線帽更改輸出電壓。
