Micro:Bit Valon-I en
Introduction
Function
Parameters
- One-key start switch x1
- Power indicator x1
- Buzzer x1
- N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Motor Control
RGB LED Control
Installation:
Read Infrared Key
Installation:
IR Remote Control
Installation: ditto.
Makecode Program Link: https://makecode.microbit.org/_C2admrTTq6m8
Read Ultrasonic Distance
Installation:
