Micro:Bit Valon-I en
2020年8月1日 (六) 14:08Allblue讨论 | 贡献的版本
Introduction
Function
Parameters
  • One-key start switch x1
  • Power indicator x1
  • Buzzer x1
  • N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Motor Control
RGB LED Control
Installation:
Read Infrared Key
Installation:
IR Remote Control
Installation: ditto.
Makecode Program Link: https://makecode.microbit.org/_C2admrTTq6m8
Read Ultrasonic Distance
Installation:
Back to homepage
