Micro:Bit Valon-I en
2020年8月1日 (六) 13:32Allblue讨论 | 贡献的版本
Introduction
Function
Parameters
  • One-key start switch x1
  • Power indicator x1
  • Buzzer x1
  • N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Motor Control
RGB LED Control
Learning Target: Learn the basic way of using ambient light.
Effect: The RGB ambient light at the bottom of the Maqueen shows a variety of colors and presents a gradient effect.
Read Ultrasonic Distance
Back to homepage
