Micro:Bit Valon-I en
Introduction
Function
Parameters
- One-key start switch x1
- Power indicator x1
- Buzzer x1
- N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Read Ultrasonic Distance
Motor Control
