Micro:Bit Valon-I en
Introduction
Function
Parameters
- One-key start switch x1
- Power indicator x1
- Buzzer x1
- N20 metal gear motor x2
Dimensions and weight
Makecode Programming Example
LED Light Flash
Learning Target: Learn the using way of LED light and buzzer. Effect: The left and right LED lights flash alternately, and the buzzer emits two different tone frequencies at intervals of 0.5 second.
https://makecode.microbit.org/_dsDPsaPaWJK6
