4位数码管模块
将4位数码管模块加入项目中,可用来显示数值、时钟等信息。
- 数码管:0.56 英寸,4 位
- 驱动IC:TM1650
- 工作电压 3V~5V
- 工作温度:-40℃~80℃
- 亮度等级:8 级亮度可设置
- 模块尺寸:50.5mm * 19.5mm
- 安装孔:3mm
- 安装孔中心距:42mm * 12mm
- 模块重量:3.8g
- 1. GND 黑线 -- Gnd(地)
- 2. VCC 红线 -- Vcc(电源+5V)
- 3. CLK 蓝线 -- 信号
- 3. DIO 白线 -- 信号
4位数码管显示模块 | Arduino UNO |
VCC | +5V |
GND | GND |
CLK | D10 |
DIO | D11 |
提示:以下程序需使用到 tm1650库文件,文件下载地址见页末 - 参考资料。下载后将其解压至arduinoIDE安装目录/libraries文件夹中,例如: "D:\Program Files\Arduino\arduino-1.6.4-windows\arduino-1.6.4\libraries"。
示例一:4位数码管显示测试
/*------------------------------------------------------------------------------------ TM1650 nixie tube This example code shows how to use the functions of the TM1650 Library. -------------------------------------------------------------------------------------*/ /*************************************************************************************/ #include<tm1650.h> #define ON DISPLAY_ON #define OFF DISPLAY_OFF #define SegmentMode _8_SEGMENT_MODE unsigned char LightLevel = LV2; unsigned char WorkMode = NORMAL_MODE; //define each segment const unsigned char Seg_test[8] = {0x20, 0x01, 0x02, 0x04, 0x08, 0x10, 0x40, 0x80}; //number 0-9 code const unsigned char Number_arr[10] = {0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f}; unsigned char i, j = 0, k = 0, l = 0, m = 0; unsigned char temp[4] = {0x3f, 0x06, 0x5b, 0x4f}; boolean err = 0; int pin_SCK = 10; int pin_DIO = 11; TM1650 tm1650(pin_SCK, pin_DIO); void setup() { } void loop() { //config tm1650 err = tm1650.DisplayConfig_TM1650(LightLevel, SegmentMode, WorkMode, ON); //all nixie tube turn on for (i = 0; i < 4; i++) { err = tm1650.DisplayOneDigi_TM1650(i + 1, 0xFF); } delay(500); //loop each segment for (m = 0; m < 8; m++) { for (i = 0; i < 4; i++) { err = tm1650.DisplayOneDigi_TM1650(i + 1, Seg_test[m]); } delay(500); } //display form 0 to 9 for (m = 0; m <= 9; m++) { for (i = 0; i < 4; i++) { err = tm1650.DisplayOneDigi_TM1650(i + 1, Number_arr[m]); } delay(500); } //display the content of array temp[] for (i = 0; i < 4; i++) { err = tm1650.DisplayOneDigi_TM1650(i + 1, temp[i]); } delay(500); //all turn off err = tm1650.DisplayOFF_TM1650(LightLevel, SegmentMode, WorkMode); delay(1000); //turn on again err = tm1650.DisplayON_TM1650(LightLevel, SegmentMode, WorkMode); delay(1000); }
程序下载地址:TM1650_nixie_tube
程序运行结果:根据显示效果看程序,更方便理解
