8*8点阵模块
2019年11月7日 (四) 15:54Admin讨论 | 贡献的版本
点阵模块
更新:新版模块使用PH2.0-5P接口,连接更加方便,使用方法相同。
  • 供电电压:DC5V
  • 使用芯片:74HC595
  • 模块尺寸:32.5*32.5*14.7MM(长*宽*高)
  • 模块重量:10.6g
  • 1. VCC -- Vcc(电源+5V)
  • 2. GND -- Gnd(地)
  • 3. SER -- 串行移位输入
  • 4. RCK -- 存储寄存器的时序输入
  • 5. SRCK -- 移位寄存器的时序输入
点阵模块 Arduino UNO
VCC +5V
GND GND
SER D10
RCK D11
SRCK D12
库函数下载:TimerOne
示例一:基本显示
Face.ino:
   Face
   ( 8x8 Led Dot Matrix with two 74HC595 on Arduino)
   by YFROBOT
#include "TimerOne.h"
#include "face.h"
// 默认显示
#define ROW_DATA ((row[0]<<7)|(row[1]<<6)|(row[2]<<5)|(row[3]<<4)|(row[4]<<3)|(row[5]<<2)|(row[6]<<1)|(row[7]<<0))
#define COL_DATA ((col[0]<<7)|(col[1]<<6)|(col[2]<<5)|(col[3]<<4)|(col[4]<<3)|(col[5]<<2)|(col[6]<<1)|(col[7]<<0))
// 垂直翻转
//#define ROW_DATA ((row[0]<<0)|(row[1]<<1)|(row[2]<<2)|(row[3]<<3)|(row[4]<<4)|(row[5]<<5)|(row[6]<<6)|(row[7]<<7))
//#define COL_DATA ((col[0]<<0)|(col[1]<<1)|(col[2]<<2)|(col[3]<<3)|(col[4]<<4)|(col[5]<<5)|(col[6]<<6)|(col[7]<<7))
// flip horizontal
#define flip_horizontal 7-screenCol    // 默认显示
//#define flip_horizontal screenCol      // 水平翻转
//Pin connected to DS of 74HC595
int SER = 10;
//Pin connected to ST_CP of 74HC595
int RCK  = 11;
//Pin connected to SH_CP of 74HC595
int SRCK  = 12;
int row[8] = {
  0, 0, 0, 0, 0, 0, 0, 0
int col[8] = {
byte screen[8] = {
volatile byte screenRow = 0;
volatile byte screenCol = 0;
// A counter to know what frame we're showing
int animationIndex = 0;
// 8x8 Point temporary array
byte brightnesses[64];
  //  Timer1.initialize(100);
  pinMode(RCK, OUTPUT);
  pinMode(SRCK, OUTPUT);
  pinMode(SER, OUTPUT);
  //  Timer1.attachInterrupt(doubleBuffer);
void doubleBuffer() {
  int k = 8;
  while (k--) {
    row[screenRow] = 0;
    col[screenCol] = 1;
    screenCol++;
    if (screenCol >= 8) {
      screenCol = 0;
      screenRow++;
      if (screenRow >= 8) {
        screenRow = 0;
    if ((screen[screenRow] >> flip_horizontal) & B1 == B1) {
      row[screenRow] = 1;
      col[screenCol] = 0;
      digitalWrite(RCK, LOW);
      shiftOut(SER, SRCK, MSBFIRST, COL_DATA); //先选择列
      shiftOut(SER, SRCK, MSBFIRST, ROW_DATA); //再送行数据
      digitalWrite(RCK, HIGH);
void UpdataDate() {
  if (animationIndex < animationFrames) {
    for (int i = 0; i < 64; i++) {
      int Dot = (animation[animationIndex][i / 4] >> (i % 4 * 2));
      brightnesses[i] = (Dot & B1) || (Dot & B10);
      screen[7 - i / 8] |= (brightnesses[i] << (i % 8)) ;
  unsigned long startime = millis();
  while (millis() - startime < animationDelays[animationIndex])
    doubleBuffer();
  animationIndex ++;
  if (animationIndex >= animationFrames) {
    //restart animation index
    animationIndex = 0;
  for (int i = 0; i < 8; i++)
    screen[i] = B0;
  UpdataDate();
face.h:
int animationFrames = 2;
int animationDelays[] = { 1000, 1000 };
// Animation is designed for 8x8 pixels
uint8_t animation[][16] = {
  { 0x55, 0x55, 0x11, 0x44, 0x5, 0x50, 0x1, 0x40, 0x51, 0x45, 0x11, 0x44, 0x11, 0x44, 0x55, 0x55 },
  { 0x5, 0x50, 0x5, 0x50, 0x0, 0x0, 0x40, 0x1, 0x40, 0x1, 0x0, 0x0, 0x4, 0x10, 0x50, 0x5 }
程序下载地址:Face
程序运行结果:点阵模块显示笑脸和囧脸~
face.h文件通过点阵取模软件 获得:
点阵模块滚屏显示,请移步:点阵模块滚屏显示
乒乓游戏程序下载地址:乒乓游戏
