Static
2017年9月13日 (三) 09:05Allblue讨论 | 贡献的版本
静态变量
static关键字用于创建只对某一函数可见的变量。然而,和局部变量不同的是,局部变量在每次调用函数时都会被创建和销毁,静态变量在函数调用后仍然保持着原来的数据。
静态变量只会在函数第一次调用的时候被创建和初始化。
示例
/* RandomWalk
* Paul Badger 2007
* RandomWalk wanders up and down randomly between two
* endpoints. The maximum move in one loop is governed by
* the parameter "stepsize".
* A static variable is moved up and down a random amount.
* This technique is also known as "pink noise" and "drunken walk".
#define randomWalkLowRange -20
#define randomWalkHighRange 20
int stepsize;
int thisTime;
int total;
{        //  tetst randomWalk function
  stepsize = 5;
  thisTime = randomWalk(stepsize);
  Serial.println(thisTime);
   delay(10);
int randomWalk(int moveSize){
  static int  place;     // variable to store value in random walk - declared static so that it stores
                         // values in between function calls, but no other functions can change its value
  place = place + (random(-moveSize, moveSize + 1));
  if (place < randomWalkLowRange){                    // check lower and upper limits
    place = place + (randomWalkLowRange - place);     // reflect number back in positive direction
  else if(place > randomWalkHighRange){
    place = place - (place - randomWalkHighRange);     // reflect number back in negative direction
  return place;
返回Arduino语法参考列表
