Arduino FFT库
2017年3月29日 (三) 10:47Allblue讨论 | 贡献的版本
Arduino FFT
  • ATmega328 @ 16MHz : Arduino UNO, Adafruit Pro Trinket 5V, Adafruit Metro 328, Adafruit Metro Mini
  • ATmega328 @ 12MHz : Adafruit Pro Trinket 3V
  • ATmega32u4 @ 16MHz : Arduino Leonardo, Arduino Micro, Arduino Yun, Teensy 2.0
  • ATmega32u4 @ 8MHz : Adafruit Flora, Bluefruit Micro
  • ESP8266 : Adafruit Huzzah
  • ATmega2560 @ 16MHz : Arduino Mega
  • ATSAM3X8E : Arduino Due
  • ATSAM21D : Arduino Zero, M0 Pro
  • ATtiny85 @ 16MHz : Adafruit Trinket 5V
  • ATtiny85 @ 8MHz : Adafruit Gemma, Arduino Gemma, Adafruit Trinket 3V
Examples
- XX :
- XX :
- XX :
- XX :
Arduino_FFT Functions
- fft_run()
- This is the main FFT function call. It takes no variables and returns no variables. It assumes there is a block of data already in SRAM, and that it is already re-ordered. The data is stored in array called fft_input[], which contains 2 16b values per FFT data point - one for real, the other for imaginary. If you are filling the array yourself, place the real values in the even bins, and the imaginary values in the odd bins. For example:
  • fft_input[0] = real1, fft_input[1] = imaginary1
  • fft_input[2] = real2, fft_input[3] = imaginary2
  • fft_input[0] & fft_input[1] = bin0 magnitudes (0hz -> Fs/N)
  • fft_input[2] & fft_input[3] = bin1 magnitudes (Fs/N -> 2Fs/N)
You will have to run one of the magnitude functions to get useful data from these bins.
- fft_reorder() - This reorders the FFT inputs to get them ready for the special way in which the FFT algorithm processes data. Unless you do this yourself with another piece of code, you have to call this before running fft_run(). It takes no variables and returns no variables. This runs on the array fft_input[], so the data must be first filled into that array before this function is called.
- fft_window() - This function multiplies the input data by a window function to help increase the frequency resolution of the FFT data. It takes no variables, and returns no variables. This processes the data in fft_input[], so that data must first be placed in that array before it is called. It must also be called before fft_reorder() or fft_run().
- fft_mag_lin8()
  • fft_lin_out8[0] = first bin magnitude (0hz -> Fs/N)
  • fft_lin_out8[1] = second bin magnitude (Fs/N -> 2Fs/N)
The output can be scaled to maximize the resolution using the SCALE factor. See the #define section for more detials.
- fft_mag_lin() - This gives the magnitude of each bin in the FFT. It sums the squares of the imaginary and real, and then takes the square root. It uses a lookup table to calculate the square root, so it has limited precision. You can think of it as an 8b value times a 4b exponent. It covers the full 16b range, but only has 8b of precision at any point in that range. The data is taken in from fft_input[] and returned in fft_lin_out[]. The values are in sequential order, and there are only N/2 values total, as the FFT of a real signal is symetric about the center frequency.
- fft_mag_log() - This gives the magnitude of each bin in the FFT. It sums the squares of the imaginary and real, and then takes the square root, and then takes the log base 2 of that value. Therefore, the output is compressed in a logarithmic fashion, and is essentially in decibels (times a scaling factor). It takes no variables, and returns no variables. It uses a lookup table to calculate the log of the square root, and scales the output over the full 8b range {the equation is 16*(log2((img2 + real2)1/2))}. It is only an 8b value, and the values are taken from fft_input[], and returned in fft_log_out[]. The output values are in sequential order of FFT frequency bins, and there are only N/2 total bins, as the second half of the FFT result is redundant for real inputs.
- fft_mag_octave() - This outputs the RMS value of the bins in an octave (doubling of frequencies) format. This is more useful in some ways, as it is closer to how humans perceive sound. It doesn't take any variables, and doesn't return any variables. The input is taken from fft_output[] and returned in fft_oct_out[]. The data is represented as an 8b value of 16*log2(sqrt(mag)). There are LOG_N bins, and they are given as follows:
  • FFT_N = 256 : bins = [0, 1, 2:4, 5:8, 9:16, 17:32, 3:64, 65:128]
  • FFT_N = 128 : bins = [0, 1, 2:4, 5:8, 9:16, 17:32, 3:64]
Where, for example, (5:8) is a summation of all bins, 5 through 8. The data for each bin is squared, imaginary and real parts, and then added with all the squared magnitudes for the range. It is then divided down by the number of bins (which can be turned off - see #defines section), and the square root is taken, followed by the log being computed.
返回Arduino库菜单
欢迎加入群聊:技术交流群
