Adafruit SSD1306库
2016年9月5日 (一) 15:39Allblue讨论 | 贡献的版本
Adafruit_SSD1306 github: Adafruit_SSD1306
Adafruit_SSD1306
Compatibility -- 兼容性
MCU Tested Works Doesn't Work Not Tested Notes
Atmega328 @ 16MHz X
Atmega328 @ 12MHz X
Atmega32u4 @ 16MHz X
Atmega32u4 @ 8MHz X
ESP8266 X change OLED_RESET to different pin if using default I2C pins D4/D5.
Atmega2560 @ 16MHz X
ATSAM3X8E X
ATSAM21D X
ATtiny85 @ 16MHz X
ATtiny85 @ 8MHz X
Intel Curie @ 32MHz X
STM32F2 X
  • ATmega328 @ 16MHz : Arduino UNO, Adafruit Pro Trinket 5V, Adafruit Metro 328, Adafruit Metro Mini
  • ATmega328 @ 12MHz : Adafruit Pro Trinket 3V
  • ATmega32u4 @ 16MHz : Arduino Leonardo, Arduino Micro, Arduino Yun, Teensy 2.0
  • ATmega32u4 @ 8MHz : Adafruit Flora, Bluefruit Micro
  • ESP8266 : Adafruit Huzzah
  • ATmega2560 @ 16MHz : Arduino Mega
  • ATSAM3X8E : Arduino Due
  • ATSAM21D : Arduino Zero, M0 Pro
  • ATtiny85 @ 16MHz : Adafruit Trinket 5V
  • ATtiny85 @ 8MHz : Adafruit Gemma, Arduino Gemma, Adafruit Trinket 3V
Examples
- XX :
- XX :
- XX :
- XX :
Adafruit_SSD1306 Reference
BLACK 0
WHITE 1
INVERSE 2
- Adafruit_SSD1306(int8_t SID, int8_t SCLK, int8_t DC, int8_t RST, int8_t CS);
- Adafruit_SSD1306(int8_t DC, int8_t RST, int8_t CS);
- Adafruit_SSD1306(int8_t RST = -1);
- begin
- ssd1306_command
- clearDisplay
- invertDisplay
- display
- ssd1306_command
- ssd1306_command
- startscrollright
- startscrollleft
- startscrolldiagright
- startscrolldiagleft
- stopscroll
- dim
- drawPixel
- drawFastVLine
- drawFastHLine
Adafruit_GFX库
BLACK 0
WHITE 1
INVERSE 2
- Adafruit_GFX(int16_t w, int16_t h)
- drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color)
- drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color)
- drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color)
- drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
- fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
- fillScreen(uint16_t color)
- invertDisplay(boolean i)
- drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
- drawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername,uint16_t color)
- fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
- fillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername,int16_t delta, uint16_t color)
- drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
- fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
- drawRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t radius, uint16_t color)
- fillRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t radius, uint16_t color)
- drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color)
- drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color, uint16_t bg)
- drawFastHLine
返回Arduino库菜单
